The received PDU on verification was found that the size exceeded than it should be.
Only the necessary parameters must be included in the switch. Check the received length of PDU. show lacp counters
Error
Received PDU %name% size exceeded. Incoming Port: %portId% PDU size: %size% required size: %reqSize%
| Name | Type |
| name | String |
| portId | String |
| size | uInt32 |
| reqSize | uInt32 |
